Bot Lobbies on PS5
Anyone know to get VPN working on PS5 to get bot lobbies? Do I need a special router or something?
Someone please help me out I’m tired of facing sweats every game.
I bet you get bot lobbies already
No one is getting 2.0kd lobbies stop capping. On a off day you might get a 1.7kd lobby. People that claim to having tough lobbies tend to avg 1.07kd lobbies.
You need a router that is capable of installing a vpn and routing trafic manually through it. I only know of netduma routers. For example a Nighthawk XR500 with a Keepsolid VPN with Libya or Dubai location. Then you can put any open vpn config into the router and manually route following ports to connect to local lobbies with normal ping and disabled sbmm
TCPUDP - Source Port (1:65535) - Destination Port (3074:3074)
TCP - Source Port (1:65535) - Destination Port (443:443)
UDP - Source Port (1:65535) - Destination Port (88:88)
UDP - Source Port (1:65535) - Destination Port (500:500)
UDP - Source Port (1:65535) - Destination Port (3079:3079)
UDP - Source Port (1:65535) - Destination Port (3544:3544)
UDP - Source Port (1:65535) - Destination Port (4500:4500)
Check out nolagvpn.com
There’s a way but if you’re embracing cheating best to just get a PC
No im looking to get the ones your in
Ik, I was just fucking with that kid cuz he was trynna act tough.
My warzone KD is 1.5, not the best but def above average, I also always solo queue since my friends like Apex more.
However, my multiplayer KD is 2.00+ but I do have a terrible W/L ratio since I leave games where my teammates suck and the enemies are stacked.
But this post isn’t about that, but I will respond to you since your comment is genuine.
i have a 5.2 and players are way better than me. lobbys im in are sweaty af
They feel like that because there is always some guy with 16 kills in a 1.07kd lobby that should not be there, getting the win.
Dude, this is a great response, thanks so much.
However I am not technically literate enough to understand all of it.
The routers you listed are above $200 and I am not trying to spend that much just to get bot lobbies since I am a casual player, however I did find a service called botlobbies which have they’re own “router” you can set up on your laptop/pc and it basically does what those routers you listed do.
Have you heard of it?
This logic is so funny.
OP, you’d have to go through your router. Look into that, plenty of resources here.
Keep in mind ya you’ll get some nice .6-.8 KD lobbies but even then, on a bad day I get the same VPNing absolute 3.0 kd demons dominating the lobby along with me 5+ games a day. At night and on fridays expect average 1.0ish lobbies even with the VPN
Its not really cheating if im not hacking is it? I’m simply using “loopholes” that your favourite streamer is using to make a game I paid for more fun. I didn’t however pay for SBMM so I will simply remove it since it is still my product, taking space, on my PS.
VPNing is very different than using actual cheats.
Also too broke to get a PC.
Link your cod tracker. I bet you do have some bot lobbies
True so because they see a 2kd guy get 16 kills they think they are in a 2kd lobby ? Haha bots
just practice more. when i played everyday i was winning games left and right. that was mw2. mw3 im not so good. but play less
Thx for admitting to using VPN.
I was just browsing r/StreamersCheating and saw a dude make a tutorial on how to VPN on console and he was using the VPN botlobbies and ended up accidentally finding and killing Nadia while showing off how it works LMFAO.
And yes, I’m not looking for bot lobbies every single game, I just want to encounter them more than what SBMM lets me. SBMM currently gives me a “free game” every 1/10 matches with the other 9 being 2.0+ KD lobbies. If VPN helps with that, I will make that investment.
Just curious, which one do you use?
It’s definitely cheating, using software to give you an advantage in a game? Does that sound like fair play? Link your cod tracker let’s see these lobbies
Yea let’s see these 2+kd lobbies
I use OpenVPN as do most, especially SBMM off even if they don’t show it. My highest lobbies are like 1.4, never seen higher than that. I still hang in the 1.0+ lobbies, 2.5 on FK for reference.
I play PC though
