I have an exit node that different peers use. The exit node can momentarily go offline. If a peer is connected to an exit node, and the exit node is down, the expected behavior is that Tailscale will block traffic (no internet). This security feature is sometimes called kill switch, and prevents traffic or dns leaks.
I wonder if Tailscale blocks connections without VPN. I asked this question here
The response was: it depends on operating system. In android, Tailscale app has a kill switch option.
How about iOS, Linux and windows?
I don’t see an option in iOS. In Linux, I don’t know if I should write my own firewall scripts.
Why do other VPNs apps such as protonvpn or Mullvad have a kill switch in all platforms, but Tailscale, supposedly a modern secure zero trust network access (ZTNA) VPN, doesn’t?!
Even the good old OpenVPN has an option Seamless Tunnel in iOS which seems to be this.
When a currently in-use exit node becomes unreachable on our supported Apple platforms (iOS, macOS, tvOS), the current behavior is that Internet connectivity will be blocked entirely until the exit node comes back online. So yeah, I guess you could call this behavior a “kill-switch”. We just don’t advertise it using that wording.
My guess is one word: prioritization. Tailscale isn’t positioning itself as a Privacy VPN, although the Exit Nodes do approximate that functionality.
There’s a Feature Request marked as pending that seems to address what you’re looking for here: https://github.com/tailscale/tailscale/issues/10773 . Although we don’t know what pending means in this case. It could be relatively soon or months/years away.
Feel free to vote on it so that Tailscale prioritizes it.
Tailscale is for creating a VPN in the traditional sense, and aimed primarily at businesses. Things like Mullvad are more like proxies and used primarily for privacy. I wrote something about this a few months back when these sorts of questions came up a lot - Tailscale vs NordVPN, Mullvad, etc
The Mullvad integration and exit nodes get tailscale most of the way there, and provide some useful functionality for businesses. But they’re not really fully comparable functionality to a standard proxy VPN tool like Mullvad, Nord, etc.
Great! Perhaps it could be mentioned in documentation, like in Mullvad:
The app has a built in kill switch that is enabled by default and cannot be disabled. This is to prevent your traffic from leaking outside of the VPN tunnel if your network suddenly stops working or if the tunnel fails for any reason. Mullvad automatically protects your data until your connection is reestablished.
How about Linux and Windows? If I use Mullvad, do I get the same behavior, or do I need a firewall script?
