Hello guys, I want the best vpn for bot lobbies?
(pls help)
I cant use nolagvpn
(pls help)
I cant use nolagvpn
ExpressVPN might be a good option for warzone. It may help you to reduce lag as well as ping during gaming. If you want to use another VPN then, I will recommend you can compare the features of all best Warzone VPNs.
This article tests the best VPNs for bot lobbies. Check it out: https://www.anonymistic.com/best-vpn-for-call-of-duty-warzone/
As the other commenter suggested, nord is the best option but there are cheaper ones that work just as well.
