I really don’t have much money at all to spend on NordVPN.
Is there a P2P allowed VPN for around £10 a year?
Thanks!
Thanks!
SurfShark.com is the cheapest one i’ve found at $2 a month, compared to nordvpn which is more popular and costs $3.50ish a month. I’ve tried them both and can’t tell any difference except in speed, nord just has more ip locations and countries you can use
Any VPN that charges 10£ a year will be worthless and leak your ip anyway, might just aswell torrent without VPN…
Ivacy lifetime is the cheapest option via stacksocial.
I got 3 years of Nord for $90 back on Black Friday with a 75% off coupon plus an additional $38 back through one of those cashback sites, though it took a month and a half or so to actually pay out. Boiled down to like $18 a year after that.
We need a bot to automatically refer these questions to a comprehensive answer stickied somewhere.
I’d recommend PIA…Just try it…I think it’s the best!
Can’t get much cheaper than using a free trial then cancelling before you get charged - https://streamingmoviesright.com/free-vpn/
I just wondered, I used a free VPN, went to nordvpn in Hong Kong, and they had a three year deal for 126 dollars, but converted to sterling was 12 quid. Would it still work, or have I made a mistake in conversion?
Hmm, okay. Currently I torrent it via Seedr free account, and download it to my PC from there. Issue is I am limited to 5.5 GB max size torrent.
I see they have a deal for 3 years at 100, but I don’t have that in my account so can’t take advantage of it ![]()
The down side to NordVPN is they do not allow any form of port forwarding which causes problems on upload. So if you have a tracker that requires a specific ratio, it takes forever to get that ratio.
Tbh, depending on wich country you live in I don’t think you need a VPN for casually dowloading, they’re mostly going after uploaders…
I live in Belgium for example and imo it’s all a big marketing scheme… you can always get unlucky tho…
UK, I think they are pretty harsh here.
None of my friends torrent, and my dad can’t share his VPN account (IDK who it is with) lol.
The ISPs log everything here, 1 year minimum by law I believe. I recommend going with PIA. It’s not £10 per year but it’s quite reasonably priced.
PIA is good because they actually protect your privacy, providing you with a lot more freedom online. Private internet access should be a right, but if we need to pay for it, PIA is a good company.
The UK is pretty bad with censorship. I think a good VPN is a mandatory purchase really.
I’m up to share my account for cheap if you want to.
I second PIA. The portforwarding service works really well, meaning your BT client remains connectable. Really the best way to go IMO
Cool, can I send you a Dm? ![]()
FYI there is potentially less privacy if you port forward. Port forwarding isn’t needed for seeding.
