Any way to use vpn on ps5 without a PC or Laptop?
Is it possible to use a vpn on ps5 with only an iPhone?
You can install a vpn directly onto a compatible router (or buy a router with a vpn already installed). Then all devices using that router will have access.
Thanks. Do you know how much they cost?
For a pre-installed vpn? There’s a wide range based on normal router things, but probably starting at $150 or so? A bit cheaper if you’ll install it yourself—just make sure that whatever you buy is compatible with the vpn you want to use.
