Hello
I’d like to connect to my universities VPN on my XP machine, but they recommend the CISCO anyconnect vpn client v4 for this, which doesn’t install on XP (too old). V3 is available, but I’m having a hard time finding an install for it, and some folks on forums have said it doesn’t work anyway.
Does anyone have a recommendation for a VPN client for XP that works like anyconnect? In other words, it has the ability to open webpages to sign in with institution credentials? I downloaded OpenConnect GUI, but it’s not as simple as I’d like. Might be able to figure it out, but I just thought I’d ask to see if anyone has suggestions.
Thanks!
