Why do make another server for SEA it should be just one.
but i do wish they can let you move your account to another server.
I did consider stop playing genshin in Asia server cause of lagging
so SEA server is blessing for me
SEA also has aussie and NZ pretty sure. No OCE server.
They are way too far from KR and JP.
I’m from sea region but the game recommend me america server why is that?
i usually choose americas servers but it recommends asia server for me, does anyone know why?
I’m from the Philippines, but the game recommended me to America Server. Should I choose america server or should I choose ASIA or SEA server? But there will be some time in the near future where I will stay in America.
From the Philippines and I’m getting recommended to go for the HMT server. Makes sense in my head since we’re close to Taiwan but idk if I’m just gaslighting myself and SEA is the actual better server (help).
When is it launch for SEA? When I enter the game, it says May 23th, wasnt it suppose to be May 22nd instead?
people are worried about server and ping/delay for no reason.
- Server ping is a factor for coop mode, but note that Wuthering Waves is primarily a single player experience which is client side and will have no lag.
meaning there is no delay whatsoever and it is not an online game unless you go coop
anyways whats the best server for filipinos?
I have the same problem, I’m from the Philippines and it recommended me SEA but I want to play with players from Japan that’s why I chose Asia but my ping is so bad it keeps on reconnecting ![]()
I played the entire until union 6 with that, but after seeing this post, I’ll try changing to SEA, hope it’s possible ![]()
I’m living in sydney. Which server should I pick?
My guess is, theres too much players on SEA that it had to be in a separate server
do u know where the servers are located? i’m in India so what server would give me the best ping?
I do curious how bad lag is. i’m from philippines so asia to me no problem
your IPS its probably routed you to america
Why would you even choose an American server when u don’t live near the America
how the hell you get recommended in America you should pick asia or sea. you might be using vpn or something.
it’s weird bc im also from the PH and my recommended server is SEA
