Which VPN solution to go with?
And has terraform modules and device policies. Great tool.
I use it for the use cases OP describes. As the Tailscale website explains “Deploy a WireGuard®-based VPN that eliminates single points of failure.”.
Main difference - aws client works with AWS SSO, but problem with AWS Solution it has bad support for Linux clients
It has been a while since this initial setup. We opened support cases for our issues and AWS basically said it was a user machine issue. It was just widespread enough for us to drop the AWS vpn endpoint entirely.
We had a wide range of issues, but most prominent was the vpn client messing with Mac DNS settings and requiring users to completely reboot their machines or routers after disconnecting.
This looks and sounds awesome since we already use terraform and this would make my life so much easier. Thank you, I’ll check it out today
