What VPN to use for torrenting
Yeah PIA is great but for some reason I can’t setup split tunneling on windows 11 with their app.
PIA is great, but they just had a price increase again. I was paying like 24.99 like 2-3 years ago. Now it’s at 49.99 a year.
what is port fowarding relevant in regards to torrenting? (the purpose) if your struggling to understand the question im asking thanks a lot!
All of these are pretty bad. Mullvad, airVPN and proton would all be better alternatives
Do both allow port forwarding and split tunneling?
Not necessary, but it gives higher upload speeds and lets you upload to more people. This doesn’t affect downlaod at all, but helps build download/upload ratio. This can help you get into and let you stay in private trackers
Another guy explained how it works in another comment here. Here is the link: https://www.reddit.com/r/VPNTorrents/comments/1g4zsmt/comment/ls7uoqg/?utm_source=share&utm_medium=web3x&utm_name=web3xcss&utm_term=1&utm_content=share_button
If it’s “free” you’re the product.
How have the airvpn speeds been for you? I currently use PIA but they raised the price of my “lifetime” subscription price guarantee so I’m considering trying someone else.
As far as I see nordvpn does not support port forwarding. Are you sure?
It has port forwarding?
Could you explain what wireguard is?
Gotcha. I have never messed with the split tunneling stuff personally.
The 3 year plan has been $80 for some time… the price increase was for the 1 year I believe.
Same thing happened to me. I’m thinking about maybe trying airvpn or just resubbing their 3 year price.
Ah, I’m forgot to answer that.
You can imagine you have a pipe, one end is your torrent client, one is divided to multiple end connect to other people torrent clients (that how p2p look like, there are no centralize servers). There is a valve in the middle can do one-way flow and two way flow. If you open the valve two way, It’s like you open port, other people can directly get to your torrent client and ask for the file, which can improve your upload drastically. But if your valve is one way, you can only download the file from other end, no one can reach you. But even with one way flow valve, you can still initiate the connection and send the data to some of the pipe ends so the upload is not zero, but very slow. Hope it help.
other than port forwarding, express is best.
I went with a year of Proton VPN Plus which was US$59.98. 30 day money guarantee if you want to try it out for a month.
https://protonvpn.com/pricing
Isn’t it cheaper to buy a seedbox?? as far as I can see the problem is uploading, because downloading is no problem with VPN.
There are no ads, data trackers, and you don’t need to add any personal data. We made it free to see if people would be interested in an Internxt VPN, and we have had over 10,000 downloads in a few months.
We will add more countries soon, and the VPN will become a paid, premium service.
