Is a VPN necessary for Cinema Hd
Yes 100 % incorrect. Throttling only apples to torrenting because they can’t feasibly block. Any other copyright infringement or http/s gets outright blocked (like the torrent search websites)
It’s a Apk that helps you know you’re connected to your VPN at all times, It will slowly fade a Green globe (connected) or a Red (!) if your VPN somehow disconnected while watching a movie.
You can google it.
Download protonvpn & VPNSafetydot
Man it’s a terrible app. Have you used other apps. I just installed it again before posting in case I was remembering wrong. Is there a special version I haven’t found. I have version 2.5.2. this thing is slow & clunky and unattractive in a way I would never recommend to a person new to this stuff. In a world where Stremio or Flixvision or even Onstream exists. Cinema feel like bottom feeding. Maybe I just don’t have the right version.
Someone’s downvoting all the answers, as is weirdly the case often here. As breadfruit said, get proton VPN free. It’s one concurrent device only, meaning you can use it on your PC, phone, and firestick, but only have it active one device at a time. Which is totally fine for free. It’s pretty bare bones… the biggest downside is and you can’t pick a country with free version. It defaults to the fastest server available which if you’re in the US will almost always also be in the US.
Edit - and no, cinema HD doesn’t use torrents so really don’t need it.
Not sure about freebies. :person_shrugging:
r/realdebrid
https://www.reddit.com/r/StremioAddons/s/BGacemcjMz
Thanks, Will look into it.
Cinema HD v2 (2.5.2)
Yeah thanks, I’ll buy the firestick soon and make sure to download Proton.
Here’s a sneak peek of /r/RealDebrid using the top posts of the year!
#1: Finally, I have a working plex_debrid setup. Makes streaming so much better. All credits to the developers who made these scripts. | 184 comments
#2: Update | 94 comments
#3: Gratitude to the real-debrid team
^^I’m ^^a ^^bot, ^^beep ^^boop ^^| ^^Downvote ^^to ^^remove ^^| ^[1](https://www.reddit.com/message/compose/?to=sneakpeekbot) ^^| ^[2](https://np.reddit.com/r/sneakpeekbot/) ^^| ^[3](https://np.reddit.com/r/sneakpeekbot/comments/o8wk1r/blacklist_ix/) ^^| ^[4](GitHub - ghnr/sneakpeekbot: sneakpeekbot from reddit)
  1. Contact ↩︎
  2. Info ↩︎
  3. Opt-out ↩︎
  4. GitHub ↩︎
If you need help dm me
That’s the one. Pretty rough.
Best one, but needs a login. https://i.imgur.com/cSgqkRH.jpeg
Don’t buy a firestick. Buy an Onn streaming box instead
You will be throttling the internet speeds you pay for for absolutely no reason whatsoever.
Thats alot for being so kind.
Feel for you :sob: Works perfect on all my fire sticks & Samsung S23+
Are you using Real Debrid on your devices?
Cinema HD is split into the following sections:
TV Shows
Movies
Featured Lists
Favorites
History
Calendar
Downloads
Settings
Check for updates
Member Activation
To make content discovery effortless, Cinema HD lets you filter content by pre-set categories: Popular, Airing Today, Latest, On TV, Top Rated, Animation, Comedy, and more. To quickly find a title, you can opt for the built-in Search function.
Most titles available on Cinema HD are watchable via free links the built-in scrapers collect. However, premium-quality links offer faster load times, crisp quality, and reliability. So, Cinema HD lets you connect premium services like Real Debrid, All Debrid, or Premiumize.
Cinema HD APK is a solid choice for cord-cutters who want a reliable on-demand content streaming experience. That’s why it has made our list of the best apps for Amazon FireStick and Fire TV.
can you explain why?
If it’s good enough for you that’s fine. Other apps do the same things only faster and with a more modern UI.
Amazon is always messing with things and they are close to running their own OS. So that could mean the end of sideloading apps. Just go through posts here and see all the posts about their devices not working.
I am not accusing them but people do think they’re purposedly bricking their devices so you need to buy a new one. I had one a few years ago and it got stuck in the boot loop mess and when I saw all the posts about it I switched to Onn. I have never heard anything about an Onn taking a shit like that yet.
It’s just my opinion and you can do what you want. Just do some research and you will see all the unhappy people with bricked devices.
