How do people find my ip adress?
  1. He may be just jocking and don’t ever had your IP address
  2. If he really has your real public IP address, he can only see the area where you are, an approximation. Only your ISP provider know your real address.
  3. The public IP is the IP of your router box, and generally routers block incoming connections on all ports, as they just allow internally-initiated communications.
  4. You should be safe, no worries :slight_smile:
any time you make some kind of remote connection or request you will provide your ip, and to be honest it’s difficult to do something with it, ok cool I know roughly the country and region where you live and even then, dorks won’t do shit.
When your computer connects to a server, it responds using your computer’s IP address. You can’t order online unless you guve them an address.
It doesn’t reveal much. It can identify the general area and your Internet provider (which typically have 100,000+ customers). The tool traceroute: Traceroute IP Address | IP2Location
shows you what someone can find out.
If you are doing something illegal, police can contact the IP provider and get your physical address. Otherwise the guy can do nothing physically.
some people use a VPN to obscure their IP, but you have to trust the VPN.
Most modems have a release and renew function that you can use to release your old IP address and get a new one using renew.
Ip addresses aren’t something that is private necessarily. Although most Internet users think of it that way, your IP address is known to all websites you connect to and all hosts you connect to.
If they are trying to hack you, that is an actual crime though
Thats a weird Nord VPN commercial. :thinking:
Here, check this link with info all about it: http://www.notanipgrabber.com/actually-an-ip-grabber
That’s a private ip schema. Only relevant to your internal network. Most private networks follow this scheme behind your router.
Your public IP is a different thing, but even then that is usually pooled with multiple users possibly having that address at different times, and can switch around unless you are paying for a static IP from your ISP; meaning you pay to get the keep the same public IP on a monthly basis.
They are just trying to scare you. 192.168.x.x will occur in most consumer/home networks (although some enterprise networks too but that’s not important). You can ignore them.
If you want to know what’s your current public IP and to rest your worries whenever someone makes that asinine threat, you can always check sites like What is my IP address location? Find out here | NordVPN.
Now if they were able to get your exact internal address and subnet along with gateway, then maybe you could have a compromise in your network. But since they said they know your address without mention of a public ip it’s safe to say you are ok.
If you are using a windows computer and want to know your private or internal address, you can open the command line by searching via the start menu cmd and typing ipconfig in the black box that comes up.
They didn’t really pull your IP they’re just bluffing
as others have mentioned, this isn’t a big deal. what type of “sever” are the both of you on? there are lots of ways to leak your IP address. if there is something like webrtc involved or you are playing a game that he is hosting, then your ip address is just exposed.
voiceless intelligent pause makeshift person ugly rustic ad hoc knee advise this message was mass deleted/edited with redact.dev
Could you not use the old ip / release … ip / renew. ??
Having your ip address is barely the equivalent to having the name of the city you live in
  1. Depending on your provider, your GPS location can often be deducted from your IP address within a few yards.
  2. Websites usually log IP addresses of visitors.
  3. Applications can log and display your IP address if programmed to do so.
  4. Using a VPN or Proxy can hide your real IP address.
  5. GPS cannot be deducted from non routable IP addresses. i.e. 192.168.x.x
  6. GPS cannot be deducted from a loopback address 127.0.0.1
References:
If you are a regular user with a standard ISP, like Comcast or AT&T, your IP address changes every so often. Also, the geolocation by IP address is pretty broad. Yes, if they have your IP, there are things they can do, but assuming you left your computer’s security configuration as is, along with the router your ISP provided you, there are mutliple layers of protection in place to keep you safe, assuming you are updating and you have not changed anything.
Just don’t run any programs you’ve downloaded unless you trust the website. Don’t get it from third parties or some person on a discord server.
No actual hacker would flex having your ip. Do with that as you will
youre in his server so… youre connecting to him, which is why he has your ip… its kinda like a phone number and youre showing up on his caller ID
Dont use nordvpn use mullvad vpn
If you do end up getting a VPN don’t go with nord do Windscribe, it’s free unless you want more locations.
Also your IP is not dangerous at all it’s just a online address so computers know who to send data to.
A super easy way if you logged into a Linux server is a quick tcpdump. There are several other ways to do this.
I know your ip address it’s 127.0.0.1
