YouTube doesn't work well with VPN recently
Does anyone noticed YouTube doesn’t work well with VPN / blocklist recently? Any fix?
I haven’t had issue with YouTube. Maybe change the location/server. Keep in mind that VPN do make your connection slower
I’m having an issue where youtube videos are loading slowly or sometimes take a page refresh to appear. But that’s because Google is trying to sabotage Firefox, not because of a VPN.
No problem here. You should try a different location node.
Had the Same Problem on Firefox
When youtube is running slow for me its usually fixed by checking for updates in the browser.
I do have issues with smarttubenext on my shield and smart tv. Set up wireguard on router and whenever im connected, every video will just blackscreen. If i switch to my wifi without vpn it runs fine. Normal YouTube runs smooth with or without vpn
I just tested with a 1080p YouTube video and it worked very well. No issues.
I’m using Mullvad VPN (WireGuard) and the Firefox browser with the uBlock Origin ad-blocker extension.
Youtube works fine with me, frontends like Invidious not so much these days (but for reasons unrelated to VPN blocking). I did notice issues with Reddit however. Mullvad openvpn has a lot of servers blocked by Reddit. Using wireguard seems to work better for now.
Not having any problems
Mine just started doing the same with NordVPN. I haven’t changed anything, at least to my knowledge. Di you ever find a fix?
How do you get around that?
I’m on Firefox, been forced to switch back to Chrome
Well don’t post your problems to the internet then if you don’t appreciate the help you’re being given. That location + server change could very well help, as YouTube could’ve blacklisted the previous ip of the server you used.
I don’t. I just refresh the page if YouTube is refusing to show me the video right away.
I use Firefox and mullvad, with windows 10, no issues with YouTube videos, I do not use an ad blocker for YouTube tho but I do use no script. Out of United States.
It’s an addon for the Firefox web browser.
