Say you find a way to use TikTok in America, like with a VPN or something, if a police officer were to see you using TikTok, would he be able to legally detain you for using this illegal website? Could you face charges for doomscrolling?
No, it is not illegal to view TikTok or use a VPN. It was only going to regulate whether Google and Apple can offer TikTok for download in their app stores.
It should be, since that website contains some real trash.
Get a VPN
Connect, change your AppleID and phone region to the same country as you set the VPN to.
Go to App Store, download TikTok
Make a new account.
Enjoy TikTok without ads or American censorship!
Ah, thank you, that’s what I was like 99.99% sure of but I was sitting there thinking about it and had to ask someone without sounding like an idiot lmao
That’s not entirely the truth either.
US ISPs are also forbidden from passing TikTok data. Some people in Canada and even Australia can’t access if for whatever reason their app was talking to a US server.
The key part of the analysis (PDF) is
prohibition on app stores and internet hosting services distributing, maintaining, or updating foreign adversary controlled applications
My understanding is that TikTok actually could stay online (you are sending messages to its servers to see messages on the mobile app and web browser) but they wouldn’t be able to provide security and feature updates. The additional language is to avoid any workaround to updating via the app stores, like downloading an updated web UI.
Absolutely false. I am in America, on TikTok on a VPN at this moment.
yes you can if you change your region lmao??
Worked for me… deleted app, turned on VPN, changed region in App Store, downloaded TikTok, created new account, working.
then don’t delete it
I never said a VPN wouldn’t work? It 100% will if you’re using a good VPN service.
The previous commenter made it more sound like the Fortnite on IOS issue. Game worked perfectly fine but wasn’t on the App Store, if you installed it alternatively things were a-okay.
With having the ban also effect passing data for hosing companies it forces the use of the VPN and could even put US based VPN companies at risk. That would be interesting to see shakeout if it does.
It works with a VPN, you’re correct.
So far I’ve seen Americans using the UK, Canada, Australia, and Mexico.
There’s a range of choices depending on the VPN.
Don’t even need a VPN now. Got a message from TikTok thanking Trumps efforts and they’re back online.
What a meme.
I saw that. The whole thing is something else
