WireGuard load testing
Hi everyone,
I’m looking for a tool to test how many connections my WireGuard VPN server can handle. Thanks in Advance.
That would highly depend. I guess when all ideling then it might go towards unlimited under full load it’s most likely the bandwidth that makes a connection unusable. What is you downlink and uplink speed. What would you consider as a usable speed. If you have 100MBit/s up/down for example and say clients will do ok with 1MBit/s then 100 connections under full load is the max.
Sure your CPU may at some point come into play too but not knowing your specs hard to guess a newish i3 should be able to handle 100 connections easily.
I’m not aware of any load testing tools for Wireguard, but if it helps, I have ~40 peers on an Intel Atom D525 @ 1.80 GHz Wireguard server and the load sits around 0.6 during the day.
wireguard is stateless, so only when a client is uploading/downloading is when wireguard is actually doing anything. If a client stops downloading/uploading you can essentially think of them as being disconnected. (unlike older VPN technologies, like OpenVPN)
Unless you are playing around with high speeds (gigabit+) and running on low end hardware then you might find you are hitting on limits on your hardware.
It’s pretty lightweight. I’ve pushed around 750mb/s through the tunnel in testing. That is with one end being symmetric gigabit and the other gig down and 200 up. I can’t really say what the bottleneck was however as it wasn’t a very controlled test. But it wasn’t really loading down the remote peer at all.
As far as total number, i’ve pushed maybe 20 peers max, and it seemed to handle it no problem.
For reference, OpnVPN in a completely apples to oranges comparison was able to hit about 80mb/s down testing between a different symmetric gig endpoint and 100mb/s down client connection but I never checked to see what the bottleneck was as I could max out at 100mb/s to the same endpoint without OpnVPN.
For testing I just used a torrent client with 5 downloads of just a bunch of junk data. So a ton of packets being sent and rather high raw data rate (not comparing actual data sent as thats not counting BitTorrent overhead). You could use something like FTP but I find that to be finiky.
How many connections? As in the number of open network connections at the same time? On a VPS you’ll likely run into Linux’s conntrack as a bottleneck first before any sort of Wireguard bottleneck. A Python (or other) script that opens connections without closing them, and can open them before conntrack times out connections will work. While running the tool to exhaust connections you’d use one of the wireguard peers until it stops working or at least becomes noticeably slow.
