I don’t understand why it’s made like this. Kill siwtch is great as a security feature but there are numerous moment where one could have a good reason to disable the vpn, server that block vpn connection, game performance, things like that are why it should be easy to disable a vpn whenever it’s needed.
So WHY do i have to manually disable this kill switch every time i need a normal connection ??? idk… the app could just disable the kill switch when you purposefully disconnect NordVpn (the idea of this feature is to prevent unpurposefull disconnection i belive) when the stop / start button is pressed and re-enable KillSwitch when the stop / start button is pressed again. Couldn’t it at least work with the pause feature ???
I don’t get the point, it’s juste a good way of forgetting I disabled it and wander around without it. If the goal is to just disable any connection without VPN what is the point of letting me stop or even pause the connection in that case ?
