When I turn on my residential zone type with Bright Data and Smart Proxy Chrome extensions and reload the webpage, I get “The site can not be reached.” How do I fix it?
What? Ayo bro i never encountered that stuff with my hproxy.
You sure buddy you configured your proxy correctly? Try with a socks5 connection.
Residential proxies can trigger security measures on some websites, blocking access. Try switching to a different IP, clearing your cache, or disabling the proxy temporarily.
Then you should try residential proxy with antidetect browser. My perfect integration till now has been 9Proxy and Dolphin Anty. Should check out them!
Connect the proxy to an anti-detect browser and then see.
I cannot connect with SOCKS5 since it is unavailable for the Chrome extension. I only know how to turn on and use the proxy with the extension. If you could help me set it up manually through Discord, I would appreciate it.
I dont know how to use discord.
You just need to download an anti-detect browser like dolphin{anty}, and then log into it. Then click on “create profile” then goto “proxy” section. Choose “socks5”. Then enter your proxy in the format of
Hostname:port:username:password
Then click on the “internet up-down arrow symbol” on the right to check your connection. If successful, it will show you the IP address (i will send a photo in your DM as i am unable to do it here)
Edit: can’t access your DMs as well. You try initiating the DM with me.
