Guys, I got the THM sub and currently running on EU-vip-2 vpn config. My wifi is fine, but I am getting laggy experience when I ssh into the THM-Attack Box. So which do you think is best and gives smooth experience for the users in india?
Also, it would be awesome if the THM team can add Indian servers for attack-box and let us choose to run it from which server.
It’s also super slow and laggy for me as well from my location. Wish they could provide us the choice which area we could deploy the machines at, or at least the ability to download the room (task) machines as docker containers so we could run them locally
The VPN is not used to access the attackbox, changing server isn’t going to help. Your best bet is going to be creating your own Kali VM and running the VPN there instead of using the attackbox.
Okay, did you check the hops with traceroute to maby locate the problem in your slow connection. If its between you and your isp then a vpn does not change anything.
