Which VPN for my phone, to use reddit?
If it matters I’m in Australia - coming for a month in February
As an Indonesian I just use a DNS hider called Intra from the app store to browse reddit
You probably don’t need a VPN service if you’re using your roaming data or eSim services like Airalo (they usually route your traffic through Singapore). Even if you’re using Indonesian WiFi enabling iCloud Private Relay (or the similar service on Android) should work. Reddit is only blocked by Indonesian carriers like Telcomcell on Apple or Google accounts set to Indonesia. Last year I bought a Samsung phone with an Indonesian sim card in Yogyakarta and I was shocked that half the websites I usually visit didn’t work, so no Reddit, no Pornhub, etc. So, I ended up gifting this phone to my mom.
I’m here currently, using surfshark with no issues
I use the Apple iCloud Relay for Reddit.:+1:
I’m using nordvpn right now
Proton VPN has been the best free VPN I’ve used
Same question, want to watch NFL on YouTube tv
You don’t need a VPN to use Reddit in Bali you can just use Cloudflare DNS - https://www.cloudflare.com/en-gb/learning/dns/what-is-1.1.1.1/
Mobile app link - https://one.one.one.one/
intra dns is sufficient. just a toggle to activate and just turn off after use it
we use nord vpn - works okayish, sometimes a bit slow but reddit works fine with it
I used this Connect to public AdGuard DNS server
Make sure to select option 2 so you don’t need to download the app for it. Works as an adblocker too
You can use pretty much most VPNs or DNS service providers. I use free version of NextDNS and paid Windscribe. Honestly NextDNS is enough but I’m into privacy stuff.
You don’t need to use a VPN at all. Just change your phone DNS to cloudflare or others.
Cloudflare Warp 1.1.1.1
Privado vpn is 10G free
Speedtest has free vpn you can toggle on from iphone es settings after you install app and it’s working … I use it currently :call_me_hand:t2:
I use Proton VPN, it’s free
I use cloud flare. It’s enough and free
Opera has built in VPN. Or duckduckgo browser
