Where to get Japanese Subtitles for Japanese Dubbed English Shows?
For example: SpongeBob, Avatar: The Last Airbender…
Netflix will do it for some shows. I love it
In general, subtitles won’t match the dubs because they have different people do translations for them, so this probably doesn’t really exist.
Netflix will do it for some shows for Japan Netflix outside Japan ,use Netflixvpn. 日本国内のVPNが対策される中注目が集まっているnetflixVPN。その名の通りnetflixなどを初めとした海外からの接続の規制をクリアするためのVPNです。通常であればTVerやhuluなどは海外からの接続ができません。その中で値段が安く回線が比較的速く安定しているのが今回紹介するnetflix VPNです
I might get it sometime then. If I had an active Netflix subscription from the U.S., and I accessed it from Japan (with or without a VPN), would that work? Or is there a separate Netflix Japan subscription service?
I have heard that. DVDs can be a good source of subs in a pinch.
Netflix is the same subscription anywhere in the world, what you can access is dependent on where you are (or where Netflix thinks you are if using a vpn).
But, as a warning, if you’re watching a English show dubbed into Japanese the Japanese subtitles won’t match the audio, as they use different transcripts.
Thanks for the heads up. I’m a little surprised how hard it is to find Japanese subtitles for Japanese dubbed English shows. It does make sense, though. If I really need subs, I guess I can always buy physical DVDs that contain the subs.
