Where is the kill switch in Cyberghost?
I’ve read that Cyberghost provides a kill switch. However, I’ve searched the settings but couldn’t find it.
I’ve also read online that it’s automatically triggered when the connection drops, how do I test that?
open cyberghost 8, click cyberghost VPN, click privacy settings, it is 3rd option.
To test, start your VPN and then either disable your network adapter or pull your ethernet cable. it will trigger.
it works for me. If you use a torrent application, go into the settings and set it to only use the cyberghost virtual network adapter, kill switch won’t even matter.
Hi there! Thanks for reaching out! As CorporalCauliflower mentioned, you will find the kill switch feature within ‘Privacy Settings,’ as you can see more about it here: https://support.cyberghostvpn.com/hc/en-us/articles/360017096200-How-to-use-Privacy-Settings-with-CyberGhost-VPN-8-on-Windows
And here are more details on how it works:
https://support.cyberghostvpn.com/hc/en-us/articles/214387805-What-happens-if-a-VPN-connection-drops-
Should you encounter any tech problems, please don’t hesitate to contact our support team by email at: [email protected] or make an online request:
https://support.cyberghostvpn.com/hc/en-us/requests/new
Can this be done in iOS?
Hello! Check these details regarding kill switch on iOS:
https://support.cyberghostvpn.com/hc/en-us/articles/360005355013-How-to-use-CyberGhost-VPN-on-iOS-
