On several occasions I’ve been unable to use WiFi in hotels or cafés because I’m using my VPN. This kind of defeats the purpose of having one? What ways are there around this? I’ve tried obfuscated servers and changing the port but no luck
For public Wi-Fi instead of full featured VPN I use free 1.1.1.1 app https://one.one.one.one/
As others said, you need to be able to use the networks DNS to get to the login page, once connected you turn the VPN back on.
If this is a real worry for you then you shouldn’t be using a commercial VPN or a public wifi at all.
It might depend on the VPN you’re using as well. I answered a similar question about hotel wifi Hotel Wifi doesn’t let me use the Reddit app or webpage
I work on an opensource zero trust overlay network. It can do the sorts of things VPNs do (and then some). Do you run your own VPN? We had this same problem when using our own tech and the answer was to use IP only, not DNS.
This has been my experience. Connect to WiFi, log in to the captive portal and then connect the VPN. Never had an issue.
GL travel routers work great with both. There are various ways to set it up, but for most folks you will need to disable the VPN to authenticate the router with the captive portal.
The plus side of using a GL travel router is you can use a personal device (like your phone) to get the router authenticated and VPN client activated, and only then turn on and connect your work device to the router without worrying about leaks.
It’s quite reliable actually I’ve using for a while
There’s also Orbot (Tor-as-proxy), but it can get slow Orbot | Tor Project | Support
Yes. Using that feature would still leak the local IP until the authentication is completed and the VPN client is turned back on. That newer feature just automates the process.
Running the VPN client on the router is typically how people use the GL routers. Either as a VPN client to proxy multiple devices through a single commercial VPN tunnel, or as a VPN client connected to a self-hosted VPN server at home - usually to reach devices inside your LAN, or to route traffic through your personal tunnel so it appears to come from your home IP while you are traveling.
The benefit of using the router as the VPN client is that you can get it all set up with a personal device, then connect a work device to the router and it’s traffic gets tunnelled transparently through the home IP (including whatever VPN it’s automatically connecting to).
No, it won’t. It specifically says that feature is only active when there is no Internet access. Do some research.
Dude, I know all the rest of your spewage. I have been a network admin at a large multinational for decades.
Then one would think you’d know better, and not by trying for personal insults and chest thumping.
Here’s the copy/past from the embedded tool-tip text from a GL router’s admin panel for the “Auto-Enable Login Mode for Public Hotspots” feature:
“If this option is enabled, this router will automatically enter Login Mode for Public Hotspots when it successfully connected to a hotspot but not the Internet. This mode will pause VPNs and custom DNS until it leave, which may cause data leaks to the provider of the hotspot (e.g., hotel/mall).”
If you’d like I can pull it from one of the other few thousand GL routers I have access to given my company is currently GL’s only official service partner.
The point of the feature is you use it to authenticate to the captive portal to get the router online. The feature specifically disables the “kill switch” functionality and the VPN tunnel to facilitate this, and then it re-enables the VPN and waits to verify connectivity before the kill switch is re-enabled. During that time, if you have a work device connected with an auto-VPN client (like Zscaler) that can’t be disabled, you’re going to have several seconds your corp VPN client will be trying to connect to your company’s server from the real IP address.
This is why it’s recommended to use a personal device to establish the connection first, and only then turn on the work device.
