What is the best antivirus and vpn for mobile?(Android)
I use protonVPN and malwaebytes personally
If you are looking for a good VPN to use I can recommend checking this spreadsheet out. It has a TON of info in it!
If you require an anti virus for an android device. You shouldn’t be allowed near the device. As long as you’re not downloading from dodgy websites and installing dodgy software. You will never ever need an anti virus. It’ll just use power and waste battery life. VPN use proton.
Idk maybe try Microsoft defender mobile?
Also you could try malwarebytes
What is the logic here, if I want to test out new programs that haven’t been tested before I feel much safer to be using an antivirus as well as the usual virustotal scan, android has basically no built in protectors against this kind of stuff
The best anti virus is common sense. If you want to test out new programs that haven’t been tested. Then you should only use trusted sources. The only way you’re going to get a virus. Is by using modded dodgy APKs. But if you are looking to use modded APKs. Then I suggest you use the megathread. Use adblockers. In your browser. Don’t open RAR files. That you’ve got off YouTube. Or totalscam dot com. Be smart. Anti virus is just bloatware that consumes power therefore shortening your devices life. Anti virus in general is just a con for old people and the less knowledgeable. OS’s are way more secure nowadays. Even windows is secure enough. People that get viruses. Deserve viruses.
