What useful Brave flags are you guys using?
Edit: Since some of you asked, here are the ones I’m using.
| Feature |
Status |
Hashtag |
| Enable Brave Rewards self-custody connection options |
Disabled |
#brave-rewards-allow-self-custody-providers |
| Use rounded corners on main content areas |
Enabled |
#brave-web-view-rounded-corners |
| Enable Brave Wallet |
Disabled |
#native-brave-wallet |
| Enable Brave Wallet Bitcoin support |
Disabled |
#brave-wallet-bitcoin |
| Brave News prompts on New Tab Page |
Disabled |
#brave-news-peek |
| Brave News Feed Update |
Disabled |
#brave-news-feed-update |
| Enable Gemini for Brave Rewards |
Disabled |
#brave-rewards-gemini |
| Enable experimental Brave VPN |
Disabled |
#brave-vpn |
| Playlist |
Enabled |
#playlist |
| Brave AI Chat |
Disabled |
#brave-ai-chat |
| Brave AI Chat History |
Disabled |
#brave-ai-chat-history |
| Brave AI Chat Rewrite In Place From Context Menu |
Enabled |
#brave-ai-chat-context-menu-rewrite-in-place |
| Brave Player |
Enabled |
#brave-player |
| Override software rendering list |
Enabled |
#ignore-gpu-blocklist |
| Smooth Scrolling |
Enabled |
#smooth-scrolling |
| Experimental QUIC protocol |
Enabled |
#enable-quic |
| Fluent scrollbars |
Enabled |
#fluent-scrollbars |
| Parallel downloading |
Enabled |
#enable-parallel-downloading |
| Tab Hover Card Images |
Enabled |
#tab-hover-card-images |
| Windows Scrolling Personality |
Enabled |
#windows-scrolling-personality |
| Elastic Overscroll |
Enabled |
#elastic-overscroll |
| Link Preview |
Enabled |
#link-preview |
| Enable the ability to configure how aggressive Memory Saver is |
Enabled |
#memory-saver-aggressiveness |
- Wondering how I made the above table?
Just go to ChatGPT paste all the flags you’re using and write the following command.
only pick enable/disable status and the hashtag and make this into a reddit table list
Hope this helps!
auto dark mode on (non-image elements)
shortcut not apps off
fluent scrollbars on
parallel downloading on
Enabled Flags:
Smooth Scrolling
Overlay Scrollbars
GPU rasterization
Tab Scrolling | Enabled - tabs shrink to a medium width
Tab Scrolling Buttons | Enabled - to the left of the tabstrip
Tab Scrolling With Dragging | Enabled - tabs scrolling with constant speed
Tab Scrolling Overflow Indicator | Enabled - Fade
Enables Display Compositor to use a new gpu thread.
Enable the ability to configure how aggressive Memory Saver is.
Disabled Flags:
Touch UI Layout
Brave playlist is my jam!
Do you have any you would recommend?
Isn’t “Experimental QUIC protocol” on Chromium Default is already Enable in source codes? So does on Firefox browser.
I meant what used to set it Enable if it already Enabled?
Do these sync at all and is there any easy way to set these all at once? I like the ones OP has. It’d be cool to just copy and paste it in some way.
New user to brave here! Can someone explain what flags are and recommend me some
touch ui layout disabled smooth scrolling disabled brave wallet disabled all the AI-crap disabled
BTW what are fluent scrollbars? I prefer the Firefox scrollbars though because they aren’t as wide as the Brave ones.
can I copy/pasta that somewhere? slick.
Yes, thanks for reminding just edited the post!
Flags are a way to activate browser features that are not available by default.
For example, Chrome wanted to allow users to try picture-in-picture video features, before rolling it out to everyone.
The feature was made available behind a flag, so any user could try it out and give feedback. The code and design were tested and polished based on the feedback, so now you can use picture-in-picture by default in Chrome,
Thank you so much, can you talk me through how to enable the flags? Do I just copy and paste each line into the flag section?
Go to brave://flags and enable/disable them.
