VPN Through hotspot mobile
Hello everyone my TV won’t let me run shurfshark in the background so I was thinking
If I run the VPN on my phone turn on the hotspot then connect my TV to my hotspot
This should work ? Just need confirmation ? Thanks :slight_smile:
If I run the VPN on my phone turn on the hotspot then connect my TV to my hotspot This should work ?
No, at least on android the hotspot traffic isn’t sent via the VPN. For it to work you would need a rooted Android and a VPN app that supports rooting. Another alternative is to run a proxy server on the phone, and use the proxy on the TV if that’s possible.
Inexpensive travel router with built-in VPN client.
Why didn’t you just try it? Lol.
But no it won’t work.
