This morning I got up and used my tunnel bear VPN and tried to play warzone but I got this message and I’ve never gotten before. Any free vpn recommendations so I can get back in the game?
Disconnect vpn before starting match by notification tray popup. You only need vpn to login
VPNs are the meaning of you have no skill and want easy kills
Vpn need to give 160ms or less otherwise it’s not gonna work
Turn off the VPN after the loading screen
Fr? That’s good to know, I’ve been keeping it on
