VPN recommendation for an indian going to china for studies
Hi, i’ll be going to china at the end of august, for studies and i’ve been looking through a bunch of reddit posts about VPNs that work in china, and i cant come to a conclusion as everyone is saying different things.
wanted to know if where i want to connect to from china matters in context of which vpn works or not, in this case connection would be to india
any recommendations?
I don’t know why you’d expect a different result by posting yet again a question that gets asked multiple times per week. The answer is that there are several that kinda work, but it is unpredictable and there are no guarantees.
The location you connect to plays no role in the matter as far as I can tell. Sometimes some server locations work while others don’t but there is no pattern to it that I’ve ever been able to notice.
No matter which country you want to connect to as long as it’s outside of China you’ll have difficulties. No matter if it’s India, EU, USA or Tuvalu. Your VPN provider should hide the real destination anyway, right?
No matter which VPN provider you’ll choose in reality you’ll find yourself switching providers and solutions over and over again. Either because it doesn’t work at all or it is very slow. There is nothing which works really all the time.
Exactly. “I have looked through multiple posts asking this question but they are confusing, so here is the same question again.”
