VPN not working, So Does Kaspersky uses UDP AND How can we change it to the TCP?
I’m using Kaspersky VPN and it’s not working on my school’s internet since last week which I think because it’s banned.
I tried windscribe and it’s was not working either until I changed the generator method to TCP in the setting of windscribe which made it work flawless.
I would buy Windscribe if the price was good for a student in Turkey (Kaspersky asked for 6 dolar (180 TL) yearly and Windscribe asking for (9 per month (270 TL) ))
Do anyone have any solution to how to bypass it? Even discord is banned…
Check if this helps:
I might be late but no more vpn in your country (banned)
If it’s banned in your country, I doubt Kaspersky would continue supporting you through with the compliance. It’s a risk situation for them as well.
Sadly nothing helpfull, tried all of them + changing DNS. Still same.
Also Kaspersky help not returning my mails about this problem.
Nah some other still works
If you have Premium then simply call them instead of sending email.
Some of them work but the popular ones don’t
