VPN not connecting on auto
I’ve just bought NordVPN plus - this is my first VPN so I’m not up to scratch with all the jargen that comes along with it (UDP, TCP, P2P, Onion over VPN etc…)
What I’m finding frustrating is when on the home page of the android app, it just says Connecting… Finding the best server. It doesn’t ever connect. I’ve went into VPN Protocols and it only seems to connect when I select OpenVPN (UDP). I get nothing when I select the recommended automatic.
Any help is much appreciated.
It could be that one of the applications that are running in the background is interfering with the VPN connection. Try restarting your device and check if the issue persists. If it does, your best bet would be customer support, as it could be that something has changed on Nord’s end (even though it’s a bit unlikely). Best of luck!
If NordVPN isn’t connecting automatically on your Android app, try a few troubleshooting steps. Since OpenVPN (UDP) works for you, select this protocol in the VPN Protocols settings. Clear the app’s cache by going to your device settings, finding the NordVPN app, and clearing its cache. Make sure the app is updated to the latest version; if not, update it. If issues persist, consider uninstalling and reinstalling the app. Additionally, check that the app has all the necessary permissions to function properly. These steps should help resolve the connection issue.
It won’t cancel my subscription if uninstall, then re-install?
