VPN kill switch - does NetworkManager suffice, or does firewalld come to the rescue?
Hello all,
Yesterday I transitioned my server over from Ubuntu Server to Fedora Server. I am LOVING it so far, but had one quick question regarding NetworkManager VPNs. I have added my Mullvad WireGuard .conf file to NetworkManager and it’s working perfectly with no leaks, but am worried about if something ever happened to that connection - would it kill all traffic, or would I unknowingly be exposing all my server traffic directly via my ISP?
I have found online some people talking about setting up their VPN configurations with the firewall to only allow traffic through certain network devices, which seems like a good plan, however I stumbled upon a forum post (How can I configure a killswitch for OpenVPN using firewalld? - #6 by vanadium - Fedora Discussion) in which someone says that simply adding a VPN config to NetworkManager is enough, and that contains an inherent killswitch. Is this true?
Thanks in advance,
You can’t block outbound traffic with firewalld. It’s “not necessary.” If you want to block outbound traffic (say, to create a leakproof VPN), you have to use iptables or ufw. Perhaps nftables too but I have no experience with it.
FWIW you mentioned Mullvad and a cursory web search shows they have a VPN application which also fails closed. The application is GUI and CLI based, and they provide a Fedora RPM for it.
The easiest way to do it without the app would be to use ufw- drop all in, drop all out, allow out to , allow all in/out over tun0 (or whatever the VPN interface is). This is like 4-5 commands for ufw…
Even if you don’t care about torrents, there are many good reasons someone would want to use a VPN kill switch. People can’t always trust their ISPs or governments and while Tor is faster than it used to be it’s blocked everywhere.
