VPN for torrenting
My isp has blocked torrenting i have used many vpns like proton but nothing worked I used a vpn called privado its workes very well but their are only giving 10 GB for free. any free solutions for it ?
I had the same issue
The reason why privado worked is it uses IKEv2 protocol which works while bypassing… But I was never able to find a free VPN with unlimited bandwidth for ikev2
I use https://one.one.one.one/ free and fast, better than others imo
Use Real Debrid to download torrents for you and then direct download from them at super fast speeds without the need for a vpn. I have been using real debrid for years to stream free netflix, hulu, prime, hbo max, etc. to my firestick and I just recently found out I can use it to download torrents for me and then I can direct download it from their server at 27 MB/s up from 3MB/s when I used uTorrent. All that and it only costs $5 a month. Check it out, it is totally worth it. there is also a whole subreddit on real debrid if you need more info.
check out real debrid here:
http://real-debrid.com/?id=7279548
Let me introduce you to today’s video sponsor: NORD VPN WITH MY LINK IT’S CHEAPER THAN EVERYONE ELSE (it’s the same but who cares)
I suggest investing into a VPN with RAM based servers and no logging. Anything “free” is not free. You are the product and they are tracking your habits. Something like Mullvad is based in Sweden which tends to have pretty relaxed laws about logs and their servers are RAM only. Plus, they’re pretty affordable.
Not necessarily VPN for torrent. I never used it. Only if you use the internet at work or in other places. Vpn if you go on the deep web but in determinate sites.
switch to steamrip. it’s direct download so no torrent required and you don’t have any setup to run. just unpack the game and you’re done
yes …PAY for a vpn. free 1s are BS anyhow… and very limited as you can see…
but as ive said b4 just dont SEED. then you dont NEED!!!
what is this tho how to use I’ve installed it but its not opening
