I’m using the windscribe app on my firestick for video streaming, but it disconnects every 5 minutes. Does anyone know how to fix this? It’s really frustrating
hmm , it works for me flawless , dont forget fire TV sticks have super low amount of RAM.
Like if you watch a 50 minute long 4k video on youtube it literally buffers its entire ram full with 2 min buffer like seriously.
if you run stuff like kodi and other “Heavier” programs its nearly a given that it kills background tasks , try to limit Ram use then it should work.
No issue on my side.
Works great for me too when I need it.
Which Fire Stick do you have?
I just picked up a refurbished 4K Max and only have minor buffering issues with one app.
How can I limit ram usage?
Only things I can think of…
Don’t power your Firestick Lite with a TV usb port; those USBs tend to be slightly underpowered for streaming devices. Use the original adapter and plug the Firestick into a wall outlet (best) or a good quality power strip.
Otherwise, maybe try a different VPN location?
I’m starting with a 25Mbps internet service (fastest wired service we can get here!), using Windscribe. I didn’t have many issues with buffering with my Firestick 4K (2018) with 1GB RAM. I mainly moved up to the 4K Max (2023) for storage (16GB), but it does have 2GB RAM.
For the app I have issues with buffering on, choosing a different city helps most of the time.
