As an ISV, I have several IoT devices (Android based) within my customer’s LAN.
My IoT devices do not touch anything locally on the LAN (in a VLAN) and just respond to my customer’s API calls out to my cloud servers which return information to the IoT devices.
My customer has begun moving to a Zero Trust Network and we’re continually having to make requests to their firewall god to allow traffic for various endpoints as we add additional capability to our IoT devices.
Q: If I were to have my IoT devices connect to a VPN (which I can control), over a single TCP port, would that solve the continual upgrade/port allows and even strengthen the customer’s Zero Trust environment?
A VPN would solve the continual upgrade/port allows that you are having to do now but it would not strengthen your customer’s Zero Trust environment and I would argue it would be a step in the wrong direction for their overall zero trust posture.
The Zero Trust model is opposite of the old Perimeter model, where things inside a network/zone are trusted. A VPN will just create a different perimeter where things are trusted, and one that is likely opaque to your customer.
I’d look at things like Cloudflare tunnel or an API gateway. These things can be better associated with identity and access policies in a way that VPNs can’t. You could also check out tailscale. It’s a VPN but they have built some pretty good identity and access controls on top of it.
If I were the network admin I would not let you do that. It adds an potentially insecure internet facing device to my network. This is assuming you are using point to point VPN. Even if you use a client to server VPN over NAT, it requires tunneling and that might be against my network configuration.
What you should do is use API gateway to distribute your calls from IOT devices, and not just keep adding end points. You can set up several for redundancy purposes and make sure the firewall admin grants access based on the DNS name, between IOT device and your end points. This way it avoids keep having to go to firewall admin to make changes.
I completely agree with the first 2 points. As for product recommendations, I would suggest NetFoundry/OpenZiti. The former is a product, the latter is the open source which NF built and maintains - https://openziti.io/. NF/Ziti have some similarities to CF & Tailscale, incl. outbound only connections, but go way beyond it in aligning to zero trust principles, supporting product/MSP providers, as well as support embedded scenarios - incl. SDKs to embed the SW in you IoT device (in this case probably using the Kotlin SDK, also incl. Android tunnelers if you want to load on OS.
For some further details vs Tailscale, I wrote this blog which I believe gives a fair comparison as to the strengths each tool has - Tailscale and Wireguard versus NetFoundry and OpenZiti.
We require a minimum account age of 30 days to participate here. No exceptions will be made.
