VPN Atlas pro 6
I have the linksys Atlas pro 6 router which works very well but I would like to install a vpn (cyberghost) directly in the router. Does this router support it? If so, how to do this
Thank you for your answer
Currently, Linksys routers, including this specific model, do not come with built-in VPN support. However, they do support VPN passthrough, which means they can facilitate VPN traffic but do not handle VPN connections directly. To establish a VPN connection, you’ll need to use third-party VPN software on your computer. These software solutions encrypt your internet traffic, ensuring privacy and security, especially when accessing public Wi-Fi networks or sensitive data. It’s important to choose a reputable VPN provider that aligns with your privacy needs and device compatibility.
Hello Thanks for your reply. I had checked all parameters in the setup
