Using Xbox Game Pass in unsupported countries (with VPN)
There is no too big input lag because of VPN?
You don’t need vpn to play in unsupported countries. Just follow these steps to bypass it:
- Sideload Kiwi browser, then install Tampermonkey extension.
- Install this script: Better xCloud No VPN - Xbox Cloud Gaming Region Unlocker
- Then install Better xCloud: GitHub - redphx/better-xcloud: Userscript to improve Xbox Cloud Gaming (xCloud) and Remote Play experiences on web browsers
What vpn did you use? I tried panda VPN but it’s not working
If you disconnect VPN, after connecting to cloud, does it keep working or VPN must stay on all the time?
And you can connect your controller with type C cable?
It depends on which country you connect to, how close the convection is to you. There will definitely be lag, wouldn’t use it for any fast games
Most people would not want to use an extra github script and external Xcloud app just to play, the whole reason for using Xbox on Quest is ease of convenience. 2 step click into Xbox
I will try this, any ways to use the quest controller instead of xbox?
Yup, it helps a lot with latency actually
Can’t you just immediately close the VPN connection when the app is loading a game?
I remember doing that on my phone when XCloud was in beta and it always worked.
But this method gives you better image quality than the official app (1080p + clarity boost), so why not? It also does Remote Play.
Oh good so it keeps working if u discinnect it.
Do u need sidequest to install APKs? Or just download from broswer and install like u did
Yup that is a good tip!
Does it do remote play for ps5?
