Using vpn for own country, and Netflix
Using a VPN but it’s using servers from my country…
When I log into Netflix with it on my profile disappears and it’s a random one … when I disconnect the VPN it goes back to normal…
Some shows are there when I’m disconnected then when I connect the VPN some shows are not available…
I’m streaming from Canada and the VPN servers I’m using are in Canada it shows…
Am I missing something?
Apparently nord vpn isn’t so good for Netflix anymore. Netflix is blocks country specific shows if you connect through vpn. That’s why you won’t see some shows with it on.
So with a VPN with servers I’m using from Canada will block Canada shows ( something like that)
Even though that’s the country I’m in?
First I have heard of that… Where did you hear it? Is there a blog or article on it?
Edit… It’s not specifically NordVPN, it’s all VPNs that Netflix is targeting… If what you say is true, then that’s the end of the justification for using a VPN for streaming Netflix…
Just as well that other services haven’t implemented this tactic…
Personally I use my VPN for security much more than for streaming.(it’s a pleasant side effect)… But this could become a problem very quickly if true…
I’m in Canada as well. From what I have seen online is that Netflix blocks location specific shows (shows only licensed fo Canada for instance) when a vpn is detected. Show that are available everywhere will still show up. From what I have seen,they are pretty good at detecting Nord vpns for Canada.
I don’t have any article but I’ve had the same expeirence. When netflix realised I’m on a vpn they blocked all shows that weren’t available globally. Which pretty much left me with only netflix originals. Luckily it was not persistent and only happened when I was jumping countries alot.
I stopped using netflix a few months ago so can’t say if it got worse recently. But for amazon prime video it’s not even letting me watch anything when I’m connected to nord. Tried a few different countries and a few obfuscated servers.
I have now experienced this myself… It really sucks… I would rather that they just block me TBH.
