Use Split Tunneling to avoid Google ReCaptchas
Hi PIA users,
I’ve been utterly frustrated by the amount of ReCaptchas I needed to solve on Google while using PIA, and I’ve been looking for solutions. I’ve found one that works for me: Use Split Tunneling, bypass IP ranges that Google uses, and have your Google connections bypass the VPN.
This may not work for some users who want to maintain their privacy while using Google Search, but I would imagine that many people wouldn’t mind that.
Here’s what I’ve done:
  • Add 142.250.0.0/15 into PIA Split Tunnel as “bypass VPN”
  • Safety check: Add applications that MUST use VPN (e.g. Torrent, TOR browser etc.) to the split tunnel as “Only VPN”
    • I double checked that the “only VPN” overrides the “bypass VPN” so i.e. if you added the Google IP ranges as “bypass VPN” and Google Chrome as “only VPN”, Google Search addresses WON’T be bypassed while using Google Chrome
  • Enjoy your Google Search without ReCaptcha!
If you’re more privacy concerned, you can finer tune the range based on your (VPN’s) geo-location:
  • Connect to your favorite VPN server
  • Check the IP address of Google.com that serves that geo-location
    • Open cmd on Windows (win+r type cmd)
    • Type “nslookup google.com
    • It’ll give you at least 1 IPv4 address, e.g. 142.251.37.120
  • Try different range sizes that contain that IP. Disconnect and reconnect to VPN and test whether the captcha is gone.
Hope you find this as useful as I have!
Cheers
Goes to a VPN sub to tell people how to bypass the VPN they pay for
Or don’t use Google?
DDG ftw.
Bing or DuckDuckGo work great for me but thankyou
As others have pointed out, google IS the enemy of privacy and deliberately messes with vpn users and goes out of it’s way to put them into recaptcha hell.
The solution is to use a different search engine, not what you’re proposing.
Ddg is what to use when using VPN. Sole purpose is to preserve privacy with VPN
This was frustrating me, so thanks.
I understand the frustration but disabling the VPN service strikes me as counter-productive. Here is what I do.
I access google.ca directly. Usually I get to the Google search immediately. Sometimes, I have to check the captcha just once. As a Google member, I reckon the cookies are facilitating the access. Then I search.
Most of the time I try to use other meta-search engines such as Duck Duck Go or Ecosia, for example. For obscure, hard to find material, I will throw the kitchen sink at the project and also use Bing, yahoo!, etc.
Better yet, don’t use PIA
Thanks for the most constructive response!
I didn’t come to the decision of bypassing the VPN lightly. Search is the most important internet experience for me. I tried to use DDG or Bing in frustration of the Google capchas, but I found them disappointing. I’ve also tried a number of other solutions like captcha solving extensions, methods that PIA support recommended (e.g. switching between wireguard and openVPN) or methods friends who work at Google recommended (e.g. logging into search and chrome) – none of them worked reliably.
I disagree that I’ve “disabled the VPN service” – as I’ve just disabled it for Google IP addresses while using Chrome. I think this is resulting in a safer experience for me, since in my frustrations with captcha or DDG, I’d actually disconnect form the VPN completely, and keep it off for hours, sometimes days at a stretch. Now that’s disabling the VPN.
I’d like to further refine this method by checking which CIDR ranges are resolving the captcha issue and only bypassing those, rather than all ranges Google uses. I’m also still open to other suggestions that would work for me.
I’m elated to say that your post has solved my problem spectacularly. The common sentiment of switching search engines is NOT an option for some people, and it makes me very sad that the majority of responses to questions about Google’s captchas come from users who rudely ignore the poster’s request and insist they know better. It took me a long time to finally find your post, but now that I have, thank you.
