Announcement Post from Ubiquiti
Overview
UniFi OS 3.1.15 includes the improvements and bugfixes listed below.
Bundled application
Improvements
- Added notifications for settings changes.
- Added disk warning when a space IO error occurs.
- Added lifespan support for KINGSTON OCP0S31024Q-A0 SSDs.
- Added notifications for changing SSH passwords in System Logs.
- Added support for IGMP Proxy.
- Added LCM/LED settings to Console settings.
- Added an Internet health widget in the dashboard.
- Added support for modifying the local admin avatar.
- Added more NTP servers.
- Allow grouping devices.
- Allow editing Local Credential when an admin has both UI Account and Local Credential.
- Allow local login using cached UI Account credentials while remote services are down.
- Improved IPsec Site-to-Site VPN stability.
- Improved Admins page UX.
- Improved internet check resiliency.
- Improved stability for installing and upgrading applications.
- Improved storage-related notifications.
- Improved login failure messages.
- Improved UniFi OS update resiliency.
- Improved SSH password validation.
- Improved remote connection resiliency.
- Improved PPPoE connection stability when IP6CP negotiation fails.
- Improved firmware download process.
- Improved Remote Access Login failure reason detection.
- Improved UX for Custom Role editing on mobile devices.
- Improved stability.
- Improved setup UX via mobile apps.
- Removed the Early Access badge from the Connect application.
- Migrated Direct Remote access feature to UniFi OS.
- Changed the default credentials to ui/ui.
- Uninstalled applications no longer back up.
- Applications are no longer bundled by default. Instead, required applications will prompt to install when new devices are detected.
Setup
- Allow users to restore specific applications during console setup and in the settings.
- Improved setup speed.
- Updated references to UniFi App on screen while waiting for setup.
- Updated the Privacy and Security page during setup.
- Updated the UI logo during setup and on the screen.
- Disconnect all SSH sessions after setup.
Backup
- Allow restoring backups between different console models.
- Improved Cloud Backup UX.
- Improved backup restore resiliency
- Redirect to the new subnet if the subnet is different after restoring a backup.
- Keep network settings from the setup wizard when restoring a backup file during setup.
- Create backups even if some of the applications fail to export. Failures are reported in the system log.
Bugfixes
- Fixed an issue where MSS Clamping was not applied to the console’s outgoing traffic.
- Fixed camera permission assignment issue when doing it through UID.
- Fixed an issue where “Transfer Ownership” would appear for the old owner after transferring ownership. The button did not work for the previous owner.
- Fixed DHCP unicast renew not using the CoS parameter.
- Fixed broken avatars in rare cases.
- Fixed disabled applications are starting after a reboot.
- Fixed missing WiFi Channel information in some cases.
- Fixed some threats that were not being blocked correctly.
- Fixed an issue where Traffic Identification would stop working after some time.
- Fixed console might appear as Offline in the Network application when it fails to fetch Geo-Location data.
- Fixed Suspicious Activity consuming high memory in rare cases.
- Fixed rare Traffic Rules scheduling issues when selecting Saturday and Sunday.
- Fixed missing console update notifications.
- Fixed wireless scheduling.
- Fixed unable to load backups during setup in rare cases.
- Fixed timezone validation issue, preventing console setups.
- Fixed link issue when using a UF-RJ45-1G module.
- Fixed rare ulogd crash.
VPN
- Fixed network connectivity loss when remote OpenVPN Client subnet conflicts with local subnets.
- Fixed an issue where the interface for Teleport VPN stays when disabling the feature.
- Fixed DNS leak when using Mullvad VPN.
- Fixed unable to establish Site-to-Site VPNs using DH groups 19, 20, 21, 25, 26, 27, 28, 29, 30, 31, 32.
Would you recommend this release?
- Upvote this post if you recommend this version
- If you’d like, leave a comment about your setup so others can upgrade with confidence
- Downvote this post if you experienced significant issues with it
- Leave a comment (or upvote an existing one) about the issues
- If you have a workaround, please share here
- Remember to file bugs with Ubiquiti
