The past couple of months have been so unreliable for Windscribe’s UK servers. Web pages don’t load, Spotify often stops mid way through songs and I’m switching servers many times a day to get the Internet back. It doesn’t matter if I’m on 4g or WiFi. Are these widespread issues?
If this continues for much longer I’m going to switch providers.
All UK servers have been, and still are, working really fast for me! (I’m in UK).
Had same problems with the UK servers. ISO torrents just sit there stalled. I jump on to the belgium one and they download straight away. Been like that for about 2 months now.
So I use IPXProxy’s UK proxy IP directly, and the connection is much smoother, at least without interrupting it. Maybe you can also try: https://ipxproxy.com/?qd=reddit&id=5
After the update, none of your protocols will connect to any server
I’m in the USA and what op said is correct. Been using Manchester and the last 2 days I have had to swap it out with other servers. If I use London crumpet the BBC iplayer won’t work.
same here - though also in uk. They’re working fine for me
P2P is blocked on one of the UK servers.
