TPB is blocking me from download links despite me using a VPN they recommend. Anyone know how to fix this?
This is an advertisement, not blockage! Learn to use the internet before piracy lol
TPB is blocking
Ne they aren’t. The shitty site you use is.
It’s probably not the real TPB link? The .onion link or another link should be ok. Are you using a proxy site?
It’s actually an ad. Use 1ee7x or rarbg
are you sure you’re using the real tpb dot org?
Just use the official domain to get to TPB
I’ve been using this mirror site with no issues:
Use the first mirror if you’re in the US.
Yeah, I’ve tried a few different proxy sites and they all seem to have the same popup
Second rarbg. Also use uBlock origin
Sod that do it properly with a torrent
Have you tried the .org proxy?
And read the megathread.
That’s worked!! Thank you!
