I really need to get tailscale working on there. But if i download it from playstore it opens and crashes immediately.
How can i get tailscale working on this chromebook.
Thanks
Also i usually use my phones data with usb tethering to give my chromebook faster internet. Tailscale works on my phone but i dont think tailscale will work across the tethered connection. So i need it working on my chromebook.
I’d think you’d need the linux version and not the android version (play store). You’d need to download and install the .deb package via terminal I think.
You can install Tailscale on a Chromebook from the Google Play Store. It runs as an Android app on your device.
Some policies might prevent you from installing Android apps on a Chromebook. If your device is on a network that prevents installing Android apps, there is currently no alternative to install Tailscale.
From the Launcher, open Play Store.
Locate the Tailscale application and select Install.
Open the Tailscale app and select Get Started. When the Connect request dialog displays, select OK.
Did it used to be managed? My youngest went through something similar, and they had just removed accounts, rather than using the powerwash function ‘start over from scratch’ and he had some account access rights issues until I wiped it properly.
Awesome analysis work! I’ve not used the Android client much, so didn’t even think about version inconsistencies. Which is a miss on my part because I have to do the same thing with the Synologys I have running it.
