Surfshark VPN Review: Is it worth it?
Anyone here used Surfshark? Is it really worth the hype or just another overhyped VPN? I’ve seen people rave about it, but I’m curious about the real deal, especially for torrenting and streaming. How it handle Netflix or other geo-locked platforms? Does it hold up for speed and privacy, or does it have annoying limits like others? Share your honest reviews!
For torrenting, surfshark is not recommended because it lacks port forwarding
Surfshark got bad USA servers , is banned for Multiple services ( like deezer, Riot games and more on EU servers as an example ) , got a unreliable killswitch , and no PF.
Speeds are fine if you ask as an example their support about multiple banned IPS on deezer and Bypass issues ( it puts rules on ALL programs regardless if set up or not which opens HUGE issues ) the simple answer is “Reinstall” and if that fails " I can confirmt he VPN works how it should" is the following answer or something similiar worded.
i would get Windscribe they work great got one of the best killswitches and multiple 10gbit locations didnt see any blocked messages so far either.
Just stay away from Nord their vpn are more and more Nortonized ( bloated and missing the focus ) and Kape for … the very colorful history of this company and leads.
they were pretty good 6 years ago maybe 7 years but went downhill , they even took once like 6 or 7 months to fix their failing killswitch and log out issues which made the VPN hardly useable you might still find in their subreddit tons of people reporting these issues.
I have Surfshark and I would not recommend it. I wish I would have never gotten the VPN.
Why port forwarding is necessary for dowloading torrents? The kill switch is not enough?
Port forwarding has nothing to do with kill switch, it’s two completely different features useful for different things. Most vpns have a kill switch, which is to prevent your true IP from leaking. It’s a privacy measure.
Port forwarding is a feature that, for torrenting, allow you to connect to more peers. If you’re downloading something, but there’s only one seeder, but they don’t have their port forwarded and neither do you, then you can’t connect to them and you won’t be able to download it. One of you must have a port forwarded for you to be able to connect, otherwise you can’t connect to each other. It’s also important if you plan on seeding torrents to others, as you’re able to connect to more leechers. So if you’re a part of a private tracker and want to build your ratio, it’s pretty important to have port forwarding. That’s why only Proton, AirVPN and PIA are advised for torrenting, as all 3 have port forwarding support. There’s not many other popular/trusted vpns other than those that support port forwarding.
Now, port forwarding isn’t an issue if you don’t plan on seeing much and you only download quite popular torrents. Otherwise, it’s kind of a must for any torrent purposes
Ok so it’s kind of a performance problem moee than a security/privacy problem, thanks
Exactly. No problem, happy to help
