I really enjoyed using Chrome cause it had automation for passwords and stuff. But now I am using ProtonVPN and Proton Pass which is also quiet comfortable and more safe. Which browser byside you can recommend for usage?
You can find some suggestions here: https://proton.me/blog/best-browser-for-privacy
Firefox is a really good choice given what will happen with Chromium-based browsers once the Manifest V3 finally drops. If you’re concerned about ads and tracking, it should be ideal to pair it with uBlock and other privacy-oriented extensions. It’s open source (as ProtonVPN and ProtonPass) and has a gigantic extension/customizability support.
If you like Chromium browsers, you could use Brave. It’s also open source, and the ad/tracker blocker is built in the browser, which means that in theory Manifest V3 won’t break the blocking capabilities.
That being said remember what you intend to use the browser for. A VPN won’t give you anonimity, that’s what the Tor Browser is for. But if it is going to become your daily driver, any of those two browsers will do!
Mullvad Browser, based on Firefox with privacy enhancements.
Firefox + uBlockOrigin
I have a librewolf + Proton pairing, however the lack of spotify DRM support is pissing me off no end
Personally, I think brave would be your best option. It comes with a built in ad blocker and you can set how aggressively you want it to block ads. You can even aggressively block fingerprinting. I’ve been using brave for a little over a year and have had no complaints.
Edit: It says on my Mac it has blocked 39,875 ads and trackers and has saved 619.6 mb of my data that would’ve been sent to data brokers and 34 minutes saved from ads.
Most people will say Firefox, and it is really good. I prefer brave thiucv
Firefox Focus never let me down
I have recently switched from Firefox to floorp because of better support for Tree Style Tabs and more accessible Settings without using config.
Brave browser. No doubt.
UI/UX is practically 1:1 to Chrome, but privacy focused and it has an integrated ads blocker (Brave Shield) that gets the job done. Recommended to many friends and nobody went back to their previous browser.
Brave is my personal choice
Try Brave or DuckDuckGo, both are very privacy oriented.
Floorp, comes from Japan and is amazingly good.
I use Mercury Browser + uBlock + DuckDuckGo
I’ve also got more extensions I use for privacy and configured some flags
i use diffrent browsers for diffrent things
microsoft stuffs (check my junk mail > hotmail) and my mircosoft forms are in edge.
chrome for youtube and google stuffs
brave everything else.
Browser : Brave, Librewolf, Mullvad
Search Engine : Startpage,Duckduckgo,Searxe
VPN: Proton
I use Brave and Startpage search
Use Bitwarden for passwords, thats makes you agnostic of the browser
