I just bought ER707-M2 and i was able to configure Nord VPN on omada controller using Open VPN. I kept on searching the internet how to set it up but cant find anything useful (or maybe i missed something during search)
Only question is how can i assign a certain device to use vpn like ASUS Vpn director. Right now, all my devices are connected to the vpn. Thanks in advance
Does Nord let you set your location to wherever? I would like to use it to do things like use my home internet in the US while I am in Mexico or another state to order things for my home and business. Amazon only shows Mexico options in Mexico.
oh, i dont know about your use case. Regarding amazon, i dont know. but you can set location. download ovpn file, open it as text file, copy the remote server and put it in the remote server section. at the very end, upload your ovpn file. if you are familiar with asus vpn settings, its almost the same
Nee hoor, je kunt daar meerdere IP adressen toevoegen, geen idee of dat nieuw is, maar dat kan wel.
Overigens bedankt voor de uitleg, net succesvol gebruik van gemaakt!
where to do you see VPN is connected? I did the same but for KeepSolid VPN and it says successful but I cant see a tunnel created in Omada controller UI… also my IP is still local… not sure whats not working.
To be honest my internet speed is crap. Without i get 26mbps down and 5 up. With vpn on I get about 20 to 23 down and 2 up. It’s enough to get the job done so yea.
