I have an SSL VPN - nothing fancy on a FortiGate 601E/v6.4.7.
Only a single portal with a single group. Very basic. 1 DIA interface and 1 LAN interface. The portal has both tunnel and web access enabled.
I can connect w/ both tunnel and web – no issues.
Can’t pass traffic over split tunnel. Diag shows "2 func=ip_route_input_slow line=2264 msg=“reverse path check fail, drop”
How can this happen, it’s a virtual ip being issued by the forti’s SSL VPN. I tried adding a route back to that fake VPN subnet but no dice. Support had no idea what to do. TY
I would start with getting to 6.4.14 or moving to 7.0.13/7.2.6, there have been several major vulnerabilities specifically with the SSL VPN feature which affect you since you’re using it.
You have a split tunnel. Your reverse source ip, is not in any destination policy for your VPN, therefore no route is pushed, your VPN client cannot find the reverse route.
Use a full tunnel or push an additional route. in case of policy based routing setup a route to the reverse source, as destination.
Small correction to some comments in here.
Routes to individual SSL-VPN users are injected directly into the kernel/FIB, they aren’t visible in get router info routing-table all
get router info kernel
tab=254 vf=0 scope=0 type=1 proto=18 prio=10 0.0.0.0/0.0.0.0/0->10.212.134.200/29 pref=0.0.0.0 gwy=0.0.0.0 dev=17(ssl.root)
This is normally done automatically, so the question why it’s failing for you remains unanswered.
Have you checked live SSL-VPN debug? It does have a line about assigning an IP to the user, maybe it will spit out some useful error?
Thanks. VPN client (forticlient) has good routes back to fortigate. I can see the traffic on the doorstop of the firewall. For fun I tried full tunnel, same result. FG saying “reverse path check fail”
Not using policy based routing.
id=20085 trace_id=2251 func=print_pkt_detail line=5727 msg="vd-root:0 received a packet(proto=17, 10.212.134.200:49827->172.16.0.7:53) from ssl.root. "
id=20085 trace_id=2251 func=init_ip_session_common line=5898 msg=“allocate a new session-15457d54”
id=20085 trace_id=2251 func=iprope_dnat_check line=5038 msg=“in-[ssl.root], out-”
id=20085 trace_id=2251 func=iprope_dnat_tree_check line=830 msg=“len=0”
id=20085 trace_id=2251 func=iprope_dnat_check line=5051 msg=“result: skb_flags-02000000, vid-0, ret-no-match, act-accept, flag-00000000”
id=20085 trace_id=2251 func=ip_route_input_slow line=2264 msg=“reverse path check fail, drop”
naw that’s not it. That’s a dial-up VPN w/ no static routes on the client. I have rfc1918 routes that point back to the firewall.
SSLN VPN Pool
get router info routing-table details 10.212.134.200
Routing table for VRF=0
Routing entry for
10.0.0.0/8
Known via "static", distance 10, metric 0, best
10.1.199.1
, via sw1 distance 0
Destination
get router info routing-table details 172.16.0.7
Routing entry for
172.16.0.0/12
10.1.199.1
Routing entry for 10.0.0.0/8
Known via “static”, distance 10, metric 0, best
- 10.1.199.1, via sw1 distance 0
This is your problem - the firewall thinks 10.212.134.x should be coming from the 10.1.199.1 path, which is why RPF fails. It should show as a directly connected Null route.
Add a blackhole route for 10.212.134.0/24 and see if it still fails
Thank you,
I’ve got to be close.
Here’s the routing info:
10.212.134.200
Routing entry for
10.212.134.0/24
directly connected, ssl.root inactive distance 0
Best selected route:
Routing entry for
10.0.0.0/8
Still seeing the reverse path check fail, drop
messages. Is that because my blackhole route above is not the “best selected route”?
Thank you,
10.212.134.200
Routing entry for
10.212.134.0/24
Routing entry for
10.0.0.0/8
10.1.199.1
I can connect no problem. Just can’t pass traffic. If I do a pcap on the FG, I can see my traffic coming into ssl.root from my VPN IP (10.212.134.200).
No Problem, it’s gone.
auto-tunnel-static-route looks to be enabled.
config vpn ssl settings
(settings) # show full | grep auto-tunnel-static-route
set auto-tunnel-static-route enable
