I already tried to unistall previous versions, tried clean cash before install the new versios, restart mobile before open the app and I always have the problem where pop up of the music open and close and I can’t listening anything…
Is there someone who’s can help me?
Is normal Spotify from Google play working for you?
Or not even the original app?
Im almost out of countrys.
Liga o vpn outra vez que isso dá reset a cada 15 dias. Liga a Espanha que funciona. Faz isso na versão experimental e como deves saber mudas a região da tua conta para a que puseste no vpn. No meu caso usei vpn super unlimited proxy ou lá o que é
Try to change your Spotify region to the UK.
If I install original app, it works fine… Any version that I try to install from Xmanager or other source, this happens…
Almost out of countrys?? Lol
Every 10/15 days just turn on vpn with the same country and open spotify…
Just that…
I saw that suggestion before, I already changed to UK and still have the problem ![]()
Did you clone the app using experimental features or is it the uncloned one? If its not cloned, try that
Just saying, my sister, my mother and I, we all have Xiaomi cell phones and no issues
I mean not sure if the model or android version
it doesnt work for my, ive tried uk, france, spain, usa, and it only works with the vpn on
Yes, but Vpn must be on. Lol
Try US, it worked for me.
8.9.18.512 super working .
Have a question safe this application ![]()
UPDATE: Hi, I tried France and worked, without VPN I had only the option to select my country (Portugal) in Spotify “Country or Region”, I opened the browser with VPN through France and option France appeared to be selected. After I selected it the Spotify app worked immediately ![]()
Thank you everyone ![]()
Is it working with vpn off
