I’m from India and it got officially included in the playstore? But not being able to login
Power VPN is the best for playing Warzone mobile, I have no problem with it. You can access any country with it and for free
oH NO HIDE YOUR ADDRESS PLZ
Germany works fine, apart from the normal graphic bugs
I use tunnelbear vpn on the closest country. U get 2GB for free with each account u create, I can play for hours with 1 account.
OP just download Power VPN and select Germany country and connect everything will be fine
nice email (dont worry i wont send you stuff unless its okay with you)
well why don’t you try it
You only need it to login. Then you can turn it off
I play without a vpn even though I live in india. After logging in (vpn required) just disconnect vpn wait for a minute or 2 in gear up and start match
Same bro I also use this, only this VPN works other VPNs get detected
Can you suggest one bro ?
They don’t look for someone who seek to play for free no worries
Anyway i just played a bit a while ago and the graphics still trash awful actually…it doesn’t even Worth to play it right now just give them time to optimize it… still the one eyed didn’t sign for them yet!
Not really a problem as long the password is hidden
You only need the VPN to log in not to play, once your on the home screen disconnect your VPN , I’ve been using free tunnelbear for months no need to make new accounts
Vpnify is free and also works fine, however u need to go through a lengthy process to make it work
me who are praying coom(codm sub joke) on iphone8 and waiting this game for about a f**king 1 year:
Letting you know, thanks
