Please help for I am a noob. I just set up my own pivpn but forgot to set up a static ip for the ip issued to my vpn server so when I disconnected my pi and reconnected it elsewhere the ip changed so now my vpn does not work. How would I go about setting it up with the new ip after setting it as a static? Or will I have to wipe the sd and reinstall the vpn with the new ip?
Setting up a static IP on your Raspberry Pi is pretty straightforward using the network manager tool. First, open your terminal and type ”sudo nmtui” to launch the network configuration interface. This opens up a blue and white text-based menu that you can navigate using your arrow keys and Enter key.
In the main menu, you’ll see three options: ”Edit a connection”, “Activate a connection”, and “Set system hostname”. Use your arrow keys to highlight ”Edit a connection” and press Enter. This brings up a list of your network interfaces - look for either ”wlan0” (WiFi) or ”eth0” (Ethernet). Select it and press Enter again.
Now you’re in the detailed configuration screen. Use your arrow keys to navigate to the ”IPv4 CONFIGURATION” field and press Enter to change it from “Automatic” to ”Manual”. Tab down to ”Addresses” and press Enter to add your static IP. Type your desired IP address followed by /24 (example: 192.168.1.100/24). Move to ”Gateway” and enter your router’s IP (typically 192.168.1.1). Under ”DNS servers”, enter your gateway IP and 1.1.1.1 separated by spaces.
After entering all settings, tab down to ”OK” at the bottom and press Enter to save. Use Tab to navigate to ”Back” and press Enter, then select ”Quit” to exit nmtui. A quick restart of your Pi will make sure everything takes effect. Pro tip: before making any changes, it’s worth jotting down your current network settings by running ”hostname -I” in the terminal - just in case you need to revert back.
Okay so I think the static ip was already set during initial config because ipv4 configuration was set to manual already and my gateway ip is already listed
You can also check the router to find something called “dhcp static lease”.
