Setting up my NAS as a vpn
Hello.
My goal is to be able to use my synology NAS at home as a vpn server to browse the internet while am outside the house with my home IP address.
I do not want to just use a regular vpn eg nord / torguard etc.
i have tried to set up the synology vpn app, and done the portforwarding on my router at home. But unfortunately, it seems I cannot connect to the vpn using my phone.
What am i doing wrong here ?
i’ve left most fields default, i’ve set auth to chap-v2 and typed in a random key
on my android, i’ve set type to chap-v2
entered my home ip, saved it and tried to connect but it just fails without any error message after a few seconds.
my samsung phone
what am i doing wrong here ?
https://kb.synology.com/en-us/DSM/tutorial/How_to_connect_VPN_server_from_Android
Scroll to the very bottom.
It says: “L2TP and PPTP are not supported on Android 12 and later; clients will need to connect using OpenVPN instead.”
Easiest and best secure approach is using tailscale. It literally took me 15min to setup my whole thing
Hey everyone,
Thank you so much for the TailScale suggestions. It works perfectly !
Your WAN ip address on your router? See below before moving forward
Did you verify you have a routable public ip address on your internet router? With a client sitting behind your router go to https://www.whatsmyip.org/ and note the ip address. Then log into your internet router and look at the WAN ip address. Do they match? No? Then either you have another router on your network or your ISP is doing CGNAT
OP I would recommend you check out tailscale. VPN made simple
If you do decide to go this route make sure you read the link from top to bottom and do all the tweaks
If you want to stick on the native VPN Synology app, stop L2TP and go for OpenVPN. Or use Tailscale.
Don’t waste your time just install tailscale and enjoy the experience
Hey OP, not sure what the end goal is but I would not recommend using your data storage device as a VPN server to route your internet traffic through. You may be able to set it up but it doesn’t make it secure nor practical, especially with port forwarding from a regular ISP router.
I highly recommend a separate device to be used for this purpose that is made to be a router. You have several options to choose from but I suggest something like the Ubiquiti Unifi routers that offer a very easy to use software to achieve what you are doing but given your ambition here you should probably explore OPNsense instead. It is just far more secure to connect to your router via Wireguard to access your home network and browse the internet through that instead of exposing your NAS to the internet.
Well with tailscale you can connect to you NAS right? But are you on your home IP all the time or just connected to your NAS?
so using android 14 (my case) its not possible to using the vpn, so that only option is using tailscale, correct?
Glad to hear you tried that out. The endless headaches of running OpenVPN von my Synology Router are really not worth it compared to the breeze and ease of tailscale.
is there a speed difference between taiilscale and the alternatives?
Open vpn. I have tried this and it works.
