Set by US city?
I’m new to the VPN game and thinking of getting ExpressVPN. My question is can you set your location based on specific US cities? For example, if I want to set my location to Pittsburgh one day and Phoenix the next, is that possible with Express VPN?
Yes, it’s possible. It’s harder to do if you run the vpn on your router but if you use the app, it takes about 3 seconds.
I have it set up on my router. Just open the router software and change locations. Takes about 10 seconds. I usually do this with my phone browser.
Great, thanks. Will Roku and its apps recognize the location if it’s setup on the app instead of the router, do you know?
If you use the app, only things running on that device will go thru the vpn. Express VPN have good support articles on all this so be sure you look at them.
