I’m hosting a Jellyfin Server to share my media with my family at home. In the future I also want to allow people from outside my LAN (e.g. grandparents, in laws, …) to access my server.
Since I don’t want to expose my server to the public internet I’ve set up a VPN that allows access to Jellyfin from certain devices (e.g. my phone).
While this approach itself works fine, it has some drawbacks
Requires manual configuration (of VPN) on each client
Some clients don’t support VPN connections (e.g. FireTV Stick)
What I’m looking for in particular is a device to connect to the TV at grandparents and in laws that
is inexpensive
supports hw-decoding (of H264, H265 and ideally AV1 at ideally 4K HDR) for (future proof) direct playback
supports connections via VPN
We use a FireTV Cube at home, but it can’t do connections to a (custom) VPN, so I can’t use it. Does anyone have recommendations for my usecase?
I’m also wondering if there is a way (without replacing the router for sth like pfSense) to use a single device (e.g. RaspberryPi) to make all the devices in the network at the remote location be able to connect to my server through the VPN. Perhaps someone has some advice in this regard too.
Look at Tailscale or ZeroTier. No configuration required, ZeroTier is a services only VPN and Tailscale is a complete tunnel VPN, they act like virtual switches so they use different IPs to your public IP, which never change.
As u/Nphusion said, residential connections don’t have static IPs (at least not where I’m from). So I’d need a solution for noticing and updating the IPs every time they changed. Does not seem to be a viable solution unfortunately.
That would be a lot of work since most home connections have a dynamic ip adresses meaning you would need to update your firewall configuration every time an ip changes.
There are services like dyndns/noip you can self host, putting a RPI at the remote locations with a client to update your server, then fetching the new IPs and reloading the rules.
Anyhow, Jellyfin/rproxy DNS or vpn you’ll need at least one service exposed on the internet
Yes I thought of that, I might be privileged to have an ISP that doesn’t do dynamic IP for the last decade, but then our biggest operator here still does (maybe not anymore for optical fiber).
There are services like dyndns/boop you can self host, putting a RPI at the remote locations with a client to update your server, then fetching the new iOS and reloading the rules.
Might be a solution to consider - thanks! I’ll take a look at
Of course, but by using a VPN I only have to open up one port to be able access everything running at home - not just Jellyfin.
